Help: Cant get P4P800-E to work with SATA RAID
Hi. I am trying to get a new build up and running, but ive come across a pretty big snag. I am trying to get a RAID setup with two 74GB raptor drives. I am using an ASUS P4P800-E motherboard. I plugged in the two sata drives onto the SATA_RAID ports on the motherboard. This allowed me to enter the FastTrack Raid Controller utility, where I was able to configure the two drives with a RAID 0 setup. So i go into the bios and this is where things start to get wierd. The hard drives are not being seen in main menu where the IDE drives are displayed. The boot menu does have an option of the FT ARY1, which i take to mean the FastTrack Array 1 boot option. When I insert my windows xp pro disk to try and install, i hit f6 when it asks me to. the part where i hit s to specify additional drives comes up, and I am trying to do this because i am pretty sure i would have to specify a raid controller like the fast track. but no drives are recognized there, and when i put in the floppy with the raid drivers on it, it just loops and doesnt do anything. if i try to continue in setup, when i hit enter to install windows it tells me no drives are hooked up. The drives are recognized when i setup the RAID array but seemingly they are not recognized after. please help, this is driving me crazy!
I'd go to the ASUS website and make sure you have the newest drivers on that floppy. When you hit "S" to specify the driver, make sure you select the WinXP driver since there are usually several options.
Yeah, i made a floppy disk using the cd that came with the motherboard. i tried to install the Fast track, SATA, and Intel Raid all with no luck. Like i said, when I try to do this, it loops, meaning after i press enter, it will say wait, and then just go back to asking me to press enter. I think this may be because before when i hit s to specify, it doesnt list any drives, hence i dont think its recognizing the raid setup. Im cluless here, anyone else think they can help? id really appreciate it.
which one do you think I'd have better luck with? If I posted pictures here would that help? as long as sometone told me how to show digital pictures, I could post what the screens for the bios and RAID setups are showing and also what happens when I try to install windows.
If it's anything like the P4C800-E DX then I think you have to change a setting in IDE configuration. Also, there might be something in "Onboard Devices Configuration."
I think its alot like the deluxe version. I did set the IDE configuration to accept the raid, and to use a SATA raid bootable optin. In the onboard devices it is set to have a RAID as well. everything seems to be okay, I can understand if the 3rd and 4th IDE channels go away after I set up the RAID array since prior to setting it up the drives were recognized in the bios. what i dont get is why does the windows setup not recognize the array or let me put on any controllers.
here are some pics of the BIOS and what happens when i try to install windows. there is also a pic where you can see that the FastTrack RAID controller says it is functional.
index.php
index.php
index.php
index.php
index.php
well I fixed it. The floopy drive was bad, so it wasnt reading anything when i tried to use it, including the RAID controllers. As soon as I switched it out everything worked great.
