Help buying cheap gaming machine
More questions, assuming I get this far:
1.
On the ASUS update website for my mobo, there is a list of updates/drivers which includes the following:
QTY Description
7 BIOS History
3 Bios Update Tool
6 Chipset
1 Audio
2 LAN
10 Utilities
8 Manual
In each category, will the selection of the latest (top) driver include all the previous updates within that category? I believe this is true for the BIOS History category, but don’t know if it’s true for the others.
2.
I have downloaded the most recent BIOS update from my computer and have saved it on a flash drive in its zipped form. I know Danny warned against updating the BIOS via the internet bec of the danger of turning the mobo into a brick, but isn’t it also possible that the file I just downloaded and saved to a flash drive was corrupted during the download? And how would I know? And is there a risk while loading it from the flash drive as well? I guess my question basically is: is it critical to update the BIOS or is this something I can wimp out on?
3.
On my zip drive my BIOS update resides in its zipped form as P5E-VM-ASUS-HD MI-0604.ROM. Once I have Vista operating can I simply plug in my zip drive and aim the update utility at it to update the BIOS?
1) Yes the latest drivers will include all of the previous updates.
2) You can wimp out on updating the BIOs.
3) No. Never update the BIOs from within Windows. Read the manual on how to update the BIOs
Many modern motherboards have an integrated flash utility, and you just need to have the .rom file on a USB drive and press a key at startup. Read the manual as Danny said for specifics on yours.
I would suggest only updating the BIOS if you need to. Some people just want to, and thats fine, too, but if theres no need, then you don't have to take that risk.
ARGH! I don't know why I said that. I didn't mean that I would update the BIOS from within windows, I meant that I'd like to load windows first and see this machine actually work for the first time then later run the BIOS setup program and use the resident EZ Flash2 utility to update the BIOS as prescribed in the manual. Thanks for your concern.
I've just gotta figure out how I'm going to do this. Maybe put the new computer right next to this one and change the plugs back and forth to alternately operate either one. We'll see.
Junior came back from the doc & whatever he's got is viral & just have to work through it. He'll be fine.
Why are you wanting to update the bios in the first place? It is honestly unnecessary unless there is an actual problem with your specific configuration, or if something is being added/fixed.
Exactly! And therein lies my trepidation in doing so, thank you. I thought updating the bios was sort of a mandatory thing to do but I've been trying to avoid doing it like the plague bec I'm basically afraid of diddling around the bios at this point and not one bit afraid to admit it.
I'm not going to power up tonight coz of sick kid. I hate to pound on this but I'm still wondering what I'm going to see on the monitor (if anything) when I first power up. While I'd like to load and run Vista first, the mobo comes with a couple cd's, one of which says it includes Vista drivers so I'm thinking this is the first disk into the optical drive, assuming everything powers up ok.
Second, because I have my HD in SATA port 1 which is for a boot disk, and my Optical Drive into port 2 which is for a data disk, I'm guessing Vista won't boot from the Optical Disk unless I change a setting in the bios. Guess the only way to find out is to load the Vista disk and see what happens.
Last question, if after powering up and I run into problems or a situation I don't know what to do about and there is no o/s loaded, is it ok to simply power the computer down? I'm planning on setting the new build right beside the computer I'm using now and simply transfer all the plugs to the new build for start up.
Sweaty palms!
Vista installation disc should be the first disc that goes into the drive. F12 or some other button should get you a boot menu, from which you can choose the optical drive. Yes, it's ok to power down using the power button. Turn it on with nothing and see if it boots. If you hear a post beep (assuming you have a system speaker/buzzer attached), it should look for a bootable device. If it doesn't power up, go through the steps outlined at the bottom of the main post in the Basic Troubleshooting Guide.
Wow! Well, powered up the new build & loaded windows. Everything was fine, I was in the 800 x 600 mode and took a look at my windows performance score and it was 1.0, based on the lowest scores. I thought that was odd and here’s why: all scores were 5.4, 5.9, and 5.9, except graphics which was 1.0 and gaming graphics which was 1.0
Hm! I thought this was odd expecially with a new HD4850 installed. Looked inside the Microfly and the fan was running on the HD4850 so it was getting juice. But “oh well” I thought, I’ll just go on my merry way and run the asus driver update disk, but first I changed the monitor from 800 x 600 to something like 1400 x 1050 to make it look better. Popped the asus disk in and during either the Intel Chipset Inf Update program or just after it rebooted for the Realtek Audio Driver Update the monitor went into spasms and ended up looking like a psychedelic 60’s album cover, bizzare colors and barely legible.
I stopped the computer, powered on again and Vista loaded just fine but it looked horrible due to the monitor. So I reset the monitor to 800x 600 and no change. So I shut down and plugged the monitor back into old standby. It powered up looking just as bizzare in XP! Oh-oh!
So I shut down, changed the cable back to analog and powered up again and VOILA, everything looks fine.
So, any idea what might have happened? Think I blew something on the digital side of this monitor or what? Yeah, I can see Vista loading but very snowy/blocky and generally horrible looking and almost impossible to read. I have a dvi to vga adapter that came with the HD4850 but I’m not gonna mess with it yet.
Any thoughts?
P.S. The temps from the Microfly thermal sensor read anywhere from 39.5 to 44.5.
I'm adding this bec I don't think I was clear in my last post.
Both my computers, old and new, have been plugged into this dsme monitor via dvi cable. Something in the new build process screwed up the digital side of this monitor bec when I plugged it back into the old computer, same problem. I discovered that by switching the monitor back to vga I don't have that problem - but I didn't have it before using the dvi cable either.
Any thoughts on what might be happening here? I'd screw a dvi to vga adapter onto the HD4850 and try that but I thought I'd better check here first 'cause if I lose the analog side too I'm SOL.
Thanks.
I'd think on the monitor, since it's the common factor between both machines. Do you have a spare DVI cable by any chance?
I put the vga to dvi converter on the port back of HD4850, turned it back on and everything is fine. Must be the dvi port on the monitor. Wonder why it would choose to die while I'm installing a new system? Just lucky? It's under a 3 yr warranty from Samsung and glory be if I don't still have the original receipt!
And no, I don't have a spare dvi cable.
Anyway when I started the build up I only connected minimum stuff; mouse and keyboard. No printers, no internet, no nuthin' else. I really want to go slowly and do it right. Anyway, in Vista I tried to set the monitor at the optimal 1680 x 1050 but could only do 1600 x 1200.
What should be next? Maybe run the disk from VisionTek with drivers for the HD4850 and Catalyst software? Set up for internet? I don't think I need to download the monitor drivers bec it's already working, albeit only on vga?
Sorry it takes so long to reply. I have to shut this XP machine down to connect the build and visa versa, and the XP takes a looooong time to load.
Oh, I forgot to ask . . . it seems Vista doesn't recognize the HD4850 and I'm guessing that loading the drivers, Catalyst & all will probably change all that?
Yes, download and install the latest ATI drivers.
Right! Please don't use the drivers from the VisionTek CD -- they will be fairly old. Go here:
http://ati.amd.com/support/driver.html
And get what you need.
Or, assuming you're running the 64bit version of Vista (fairly sure you are, just too lazy to go back through the thread) just grab this file:
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/gamesite/8-10_vista64_dd_ccc_wdm_enu_69565.exe
That's Catalyst 8.10 for Vista 64 (as made obvious by the file name, I suspect) released October 15th. Current as of tonight.
I did run the visiontek software disk last night and it allowed me to load the drivers & Catalyst and correct my monitor settings to 1680 x 1050 for my 22” Samsung (which has probably lost its dvi port which bothers me a little but not severely since it’s still under warranty, plus you really can’t tell any difference between the dvi and vga ports in normal use). Helluva time for it to die just the same.
Catalyst has a prompt for upgrading the drivers and I’ll do that along with windows updates, virus software, etc., when I first go on-line, which I haven’t done yet – thanks for the web-sites to do so. As I recall, ATI updates Catalyst almost monthly & I’m sure these drivers are old but they got me going. Interestingly enough the Windows Performance Scores for this computer’s graphics went way up to 5.9 from 1.0 after installing the drivers so at least now I know that Vista recognizes the HD4850.
Which leads me to another question since you folks all seem to know what you’re doing better than anyone else I have ever asked about computers; I have used AVG free in the past with success and plan to continue with this build, however lots of other crap sneaks in since four adults use this computer & lots of web surfing. What program(s), free and/or otherwise, do you recommend to keep other infections and spyware out of a computer?
I have found CCleaner (Crap Cleaner) and Ad-Aware to be somewhat helpful. I also use PC Wizard and/or Belarc Advisor to help keep track of what’s on my computer.
Hope to get on-line and e-mail set up today sometime. Thanks again.
I generally just run NOD32 antivirus (not their security suite thing, though that's an option) with malware detection on and Vista's Windows Defender. A license is something like $60 for 2 or 3 years?
I use Nod32 AV as well on my own gaming rig. However, since I do have about six other computers in the home to protect and don't feel like shelling out the cash for each PC, I use the free Avira Anti-Virus on those other PCs. IMO, Avira is MUCH better than AVG. Faster and less bloated, the only gripe about Avira is that it has that annoying popup ad every once in a while for the paid version.
Other software that I use:
- Spybot S&D
- CCleaner
- Comodo Firewall
And of course Firefox, Opera, Chrome and IE7 are installed and fully updated.
Malware Bytes
Xoftspy se
ZoneAlarm Firewall
Hijackthis (only if you REALLY know what you are doing)
NOD32 AV
Symantec Corporate...
Are all great tools for security. Keep in mind more than one antivirus program is usually a bad idea due to conflict.
I think that's part of the problem I have with my xp machine - too many programs running and still not enough protection. WIll check out all others mentioned, thank you.
WOW! The new build is fast. I’m back on the old one just now only to get some info off of it. Been spending most of the afternoon updating windows, downloading drivers, setting up internet explorer and e-mail (I have used Outlook Express my whole life w/windows but think I’ll try Outlook for a change). Friend of mine works at U of H and early this yr picked up a vy inexpensive version of Office Enterprise 2007 so I have the full Office Suite.
Question 1: I read somewhere to turn off indexing bec it’s a system hog. Do you recommend it?
Question 2: Committed a computer build fashion faux pas. Mamma loves the Vista screens & all but asked me, “Why isn’t there a pretty blue light inside your computer?” I think I showed her a pic of one on-line which she liked so much. Anyway I guess it’s simply a matter of finding a fan to fit that has blue LED’s. Any suggestions other than to just shop it?
Wow! I’m maxed out downloading on a slow speed DSL line but better than dial-up on a modem. I’ll do a re-cap on this experience tomorrow or later, but for now just thanks to all for your help.
Oh, BTW, AVG is up to 8.0 'cause I just downloaded it before I started all the updates today.
If you don't use the search feature often, Indexing is a waste. Kill the service -- Google will tell you how.
Does the MicroFly have a window? Might consider getting a cheap cold cathode kit, or like you said, just a couple of 120mm blue LED fans.
A Cold Cathode bar will be your best bet if your fans are not lit. One bar near the window will illuminate the whole thing nicely.
Interesting. Never heard of a cold cathode bar before. Now I know where the kids get 'em for their cars - I always thought they were neon. I think the blue lit one my wife saw was an LED in the fan type. Yes, my Microfly has the see-thru top and sides - I didn't know if they came including the "blue light special" or not. Apparently not.
If the fans (maybe just the larger rear fan) are easily removed in the Microfly that might be the way I'll go bec I don't want to add any more heat inside the box 'cause I think there's enough already plus I'm thinking there might be less wiring (not my strong point). I don't want to light a room, just a nice soft "night-light" effect inside the box.
Besides never thinking I'd build my own computer I doubly never thought I'd be shopping for a blue light for one.
Oh yeah, user Drakan290 said he's built a lot of Microflys. Maybe he'd know. Can I send messages to users directly or only on the forum we're on?
Many kits are doubles so you can run one veritcal and one horizontal adjacent to the window this methods gives maximum illumination too
I'd prefer LED strips of some sort over cold cathodes.
edit: I hit send prematurely earlier.
They consume less power, don't get hot, and are easier to hide. If you pack them tightly enough, you'll get almost even lighting, depending on the LEDs used, hehe.
Only snuck in enough computer time today to load and play a little Call of Duty and in the process came up with a question:
I have my computer speakers plugged into the rear port for speakers and when I plug the headsets in the front headset jack it's supposed to mute the rear output device, but it doesn't. Any thoughts or solutions?
Thanks.
I assume your board uses a Realtek HD Audio codec for sound? Most do anymore.
Get their latest drivers and poke around in the supplied Realtek control panel software. It'll be a little speaker down in the system tray, but different from the default one. (2.07 for Vista, current as of this post: http://www.techpowerup.com/downloads/1226/Realtek_HD_Audio_2.07_Vista.html )
I generally check their site for the latest version number, then use Google to find a mirror -- their servers are horrible.
Thanks for your reply.
Yes, my board does use Realtek HD audeo for sound. I think I do have their latest drivers and yes, I found the little speakers down in the system tray, the silver one is for the Open Volume Mixer and the gold one is for the Realtek HD Audio Manager. When I click on the "Device advanced settings" I can click on a button which says, "Mute the rear output device, when a front headphone plugged in." I have done this and I still get sound coming out of the rear plug for "Front Speakers Out" (green) even after plugging headsets into the front headset port. Haven't been able to figure it out yet.
Well, I went to TechPowerUp and downloaded Vista_R207.exe and ran it. Now the little gold speaker has disappeared from the system tray, I still get sound to my speakers but nothing from the headset jack. Hmmm!
Oh, and plugging the headsets into the front panel still does not mute the speakers.
You have to run it twice -- once to uninstall the old drivers, again after reboot to install the new ones. It's not the most intuitive thing, though it does prompt you to do this..
I did forget to run it twice but now I did. The little gold speaker is back for the Realtek HD Audio Manager, but I'm getting no sound out of my headset jack and when I plug the headsets in it still doesn't cut out the speakers even though I have made that setting in Device advanced settings. I'm stumped.
Sorry about the multiple posts but I've been chasing this audio problem where, A) I'm not getting any signal from the headphone jack on my front panel, and B) when I do jack into the front panel it doesn't cut out the speakers.
I'm wondering if the plug into the mobo from the headphone jack is perhaps an AC'97 type plug vs. an HD plug? And if so I wonder if downloading and running Realtek AC'97 Audio Codecs will solve the problem?
