Its been a few years since I have built a system and I could use some advice/critique. Im basically needing something that can handle all my 3D programs: AutoCad, Solid Works, ANSYS, Photoshop and be good for multimedia.
So some basic Needs:
-$1000 budget for computer only
-handle all my 3D software and not slow down when I have lots of programs open, not likely to be playing any games
-perform well on 1920X1200 resolution
-last about 3 years RELIABLY
And here's what I have so far(nothing is set in stone except maby the case):
case: LIAN LI PC-7B plus II Black Aluminum ATX Mid Tower Computer Case
MB:[/B] GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail
CPU: Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400 - Retail
video: HIS Hightech H485QS512P Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported IceQ4 Video Card - Retail
memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - Retail
PSU: CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
hard disk(x2): Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
drive: SONY 22X DVD Burner w/ LightScribe Black SATA Model DRU865S - Retail
sound: Creative Sound Blaster SB0570 Audigy SE 7.1 Channels PCI Interface Sound Card - Retail
as its sits its $938
Thanks for your help!!
