IllegalEagle
- Jun 9, 2006
This is going to be a media center PC. I hope to have it connected to a TV in the next room. I hope to stream via the network 1080p and 720p video from my main rig to the TV. I prefer the PC be as simple as possible. No optical drive is needed, a large HDD is unnecessary (Just one large enough to boot Windows, nothing else will be installed) I was thinking about a Z68 setup with using the onboard GPU. Quiet, cheap, low power. Less is more.
Under $500 would be ideal but in reality the cheaper the better.
New York, NY.
Smaller the better case
CPU
RAM - 4GB? 2GB?
Mobo
HDD/SSD - Smaller the better? 10-20GB.
Power Supply - Low power. 300w? Maybe less if possible?
No parts will be reused.
6) Will you be overclocking?
If possible, but only if necessary. I'm not too sure a 2500 or something similar could run 1080p video.
1920x1080, for use on a plasma TV.
Within the next 2-3 months, but I'd like to start planning now.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Ideally it's a mini/micro board with onboard WiFi. If not, I can get a mini-adapter just the same.
I have Windows 7 Professional x64
New York, NY.
CPU
RAM - 4GB? 2GB?
Mobo
