This will be a HIGH-END Workstation PC. The main use will be for 3D art and Adobe software such as Photoshop, After Effects, Cinema 4D, Maya, ZBrush, etc. It will be used as my primary work computer for rendering, with two additional computers I already have as part of the render "farm".
I will also use it for some games at times, but gaming is not my priority.
$6,000
USA
CPU
Motherboard
32GB of RAM (the best)
1200 watt Gold or Platinum Power Supply
nVidia graphics card GTX 680 or better (must have "CUDA" for my software).
DVD Burner/Blu-Ray
256GB or better SSD
2TB Hard Drive
LARGE case that supports E-ATX and perhaps HPTX.
Corsair H100 cooling or better.
Mechanical Keyboard - Blue or Brown switches.
NONE
6) Will you be overclocking?
YES
24 inch 1280X1020 Professional Graphics monitor with full Adobe and Pantone color reproduction measured at 100%
NOW
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
UEFI
USB 3.0
eSATA
Thunderbolt (for future use)
SLI
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
YES. Windows 7 64 bit
$6,000
USA
CPU
Motherboard
DVD Burner/Blu-Ray
256GB or better SSD
2TB Hard Drive
NONE
YES
NOW
UEFI
USB 3.0
eSATA
SLI
