Help building a hybrid high end system
glopez
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? Etc
Aside from gaming, I will be rendering high end graphics using engineering software and running complex mathematical and physics simulations as well and extensive programing using a variety of tools and compilers.
My budget is not a problem; I have an ongoing engineering school budget, but I don’t know where to start to build a hybrid high end system gaming/workstation.
I live in New York City.
See answer for question 2!
No!
6) Will you be overclocking?
Not sure!
I plan to use three 22” to 30” monitors.
I will begin acquiring the parts once I get a detailed plan and outline of what I need and I have a building timeline of 3 – 6 months.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
For high graphics I would prefer a 3-way SLI setup and support as well as the demanding processing power and required ram necessary.
No!
How far do you live from these Microcenter stores?:
http://www.microcenter.com/at_the_stores/westbury.html
http://www.microcenter.com/at_the_stores/yonkers.html
Thats way too long of a build time: Our parts recommendations tends to change over time due to parts becoming out of date, out of stock, overpriced, or outperformed. So parts we recommend one month may not be the same parts we recommend in another month. So if you really want a detailed build plan that won't get outdated, please come back when you're 1-3 weeks away from buying the parts all in one go. At most, your build timeline should be a month.
Though for a general build list:
Intel 3930K CPU
Socket 2011 mobo with eight RAM slots
32GB of DDR3 RAM
128GB to 256GB SSD
1TB to 2TB Hard drive
$400 to $600 video card with at least 2GB of VRAM
Solid 650W to 750W PSU, Maybe 850W if going SLI/Crossfire
