Help Building A Gaming/Htpc Computer
MenaGear
Gaming(Crysis) HTPC, It's going to be my TV also
1000-1200 without taxes
3) Where do you live?
New York, NY
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything
Nothing Everything is going to be new
6) Will you be overclocking?
Probably
I plan to have a 22-24 But don't Include it in the list
In 2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
The really important stuff
10) Do you already have a legit and reusable/transferable OS key/license?
I already Have windows vista 64x
eVGA GTX 275 video card, i7 920 processor combo
antec mini p180 (on sale right now... this is a steal!)
If you are looking for a quiet case, this is the one to get. Also, stay away from case's with small fans eg. <=80mm
corsair 650W power supply
6GB OCZ Gold memory
western digital caviar "black" hard drive 500GB 32mb cache 7200 RPM
lite on dvd burner
Zalman heatsink with 1366 support clip
Grand Total (with shipping to Chicago): $1,155.43
If I were shopping for a gaming/home theater pc right today, this is exactly what I would buy. I would probably throw in a blu-ray drive and a nice sound card. The asus rampage gene has a better "onboard" sound card if you don't plan on buying a dedicated. gl with your build and happy fragging!
Go with It_shiro's suggestion with the corsair memory and evga mobo combo and save an extra 10 bucks off the grand total!
EDIT: sorry for double post
Case is a matter of personal preference. So go with either the Antec or Lian Li case mentioned in this threa so far.
I would not go with the WD 500GB Black drive as it is a horrible buy for the money since you can get the slightly faster and larger WD 640GB Black drive for $5 more.
I would not go with the Zalman 9500 HSF since there are significantly better HSF out there nowadays for the same or lower price such as the following:
$25 - Xigmatek HDT-S963 92mm Rifle HSF
$40 - Thermalright Cogage TRUE Spirit HSF
Mobo wise, you really can't go wrong with either the eVGA mobo that lt_shiro recommended or the Asus Rampage gene that reasoN recommended.
GPU wise, I like the HD4890 better since it's $10 cheaper but slightly faster than the GTX 275.
I just did some research on heat sinks, here are top choices: Prolimatech Megahalem, Xigmatek's Thor Hammer and Dark Knight, They are expensive, starting at about $45. The Thor Hammer is sexy, I might add.
Say no to push pin retention systems!
