Help build PC for under $500 that can handle CSS
Invalid
Hello, my friend asked me to build the best pc for under $450 that can handle CSS well. Any suggestions would be greatly appreciated.
I want to go for a core 2 duo but dont know if that is possible in that price range and a 7800gt. I need help selecting a platform.
I got this figure out so far:
Seagate 250gb HDD 69.99
G skill DDR2 2gb RAM 44.99
Decent case $50 Recommend me a good cheap case
Thermaltake TR2 PSU $48
I got it to $217 without the Mobo, CPU or graphic card. Please suggest a good platform, cpu, mobo, gfx card that can handle CSS.
Intel Pentium Dual Core E2160 CPU - $78
Gigabyte GA-P35-DS3L Intel P35 Motherboard - $90
G.SKILL F2-6400CL5D-2GBNQ 2 x 1GB DDR2 800 RAM - $45
Antec NSK4480 ATX Case With Antec Earthwatts 380W PSU - $68
MSI NX8600GT-T2D256E OC GeForce 8600GT 256MB PCI-E Video Card - $95
Western Digital WD3200AAJS 320GB 7200RPM SATA 3.0Gb/s Hard Drive - $76
Total: $452 Plus tax and shipping.
The above should handle CSS pretty well depending on the monitor size. Speaking of which, what size monitor does your friend have?
Lol believe it or not...he on a 14inch lcd i believe.
Is the e2160 good enough for CSS? What about getting a 7 series gfx card to save money and get better cpu. That might be better for css performance since eye candy isnt a big deal.
you got it backwards, more gpu, less cpu is a better idea. Danny bui's recomendation seems good to me. However, if you can wait for another 5 days, AMD will be releasing the HD3600 series, which might usher in a whole new era of awesome price performance! It might also be as big a flop as the X1600s :\.
the 7 series is dead, or at least is supposed to be. When both Nvidia or ATI start a new series, they release a top to bottom line of cards. The 8400GS is supposed to be the entry level to the 8 series at about $60 bucks, climbing to the 8500GT at about $80, the 8600GT at about $100, the 8600GTS at $130, the (unreleased) 8800GS at $180, and then the convoluted enthusiast stuff.
as a power supply, dont get the TR2s. They're crap. Get an FSP or Xclio. These power supplies wont break any records for efficiency, but the output is at least moderately clean.
is the power supply coming with this case enough?
only 380w
As was said earlier, the PSU that comes with the NSK that Danny recommended is adequate. Despite it being only a 380W PSU, its built by Seasonic and is heavy on the +12V rail, which is where most of your system will draw its power from. It has 27A on the +12V rails, which is more than that TR2 430W/450W, not to mention its also 80+, while the TR2 is only 65-70% efficient.
If you're reading this on 1/19, check this deal out:
Antec SonataIII $75 - $25MIR @ Fry's
http://www.hardforum.com/showthread.php?t=1264846
Since he's on a 14" LCD, the 8600GT will be fine, lol.
Yeah, it really doesn't take much to run most Source based games. The 8600GT is more than adequate for your friend, especially with a 14" LCD monitor, which is 1024x768 I believe? Hell I just upgrade my friend's rig with a 6800GT and it plays the Source based TF2 pretty well. His other specs include:
P4 2.6Ghz
1GB DDR 333 RAM
Some HP mobo with AGP4x max
Earthwatts 380W
Runs TF2, HL2, and Portal pretty well at 1024x768. So the system I listed in my build above will be more than enough for CSS.
OOOK. WOWOWOW. I'm done with H until they get this crap sorted out. Random deleting of posts ft fuckin L. Ill say my main point one more effin time.
wait until the 23rd of jan to see if ATIs new HD3600 cards are decent.
Oh yeah, forgot about those cards and missed your earlier post. My bad.
Anyway I agree with waiting. It's only 4 days and those cards *might* be worth it. Then again, they could turn out to be like the 8600GTS.......
for value and performance you really should not overlook the AMD x2's check out this system:
Rosewill R230-P-BK Black 0.5mm SECC Steel ATX Mid Tower Computer Case $21
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147075
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
GIGABYTE GA-M61SME-S2 AM2 NVIDIA GeForce 6100 Micro ATX $47
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128045
GECUBE GC-HD3850PG3-D3R Radeon HD 3850 256MB 256-bit GDDR3 $169
http://www.newegg.com/Product/Product.aspx?Item=N82E16814241066
SeaSonic SS-500ES ATX12V/V2.2, EPS12V/V2.91, 500W, PFC, 80+ $69
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151040
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) $49
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
AMD Athlon 64 X2 5200+ Windsor 2.6GHz 2 x 1MB L2 Cache Socket AM2 $109
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103056
Total after MIR $445
Here is a link to Tom's Hardware chart which shows how cpu's and gpu's etc peform.
http://www23.tomshardware.com/cpu_2007.html?modelx=33&model1=923&model2=883&chart=425
The link here is a comparison between the amd x2 i have chosen for you vs. the e2160 from one of your earlier suggestions. As you can see(in the chart the bars in red are the ones selected) highlighted in a game like Prey which is pretty demanding the amd averaged 91.4 fps and the e2160 only 72.9 fps.
You can use the chart to see what other ones you are looking at. The budget of $450 is very tight but I can honestly tell you that you would be hard pressed to put together a more quality build than what I have listed above. Do not cheap out on the psu, most video cards these days need minimum 400-450watts and 24-26 amps total on the 12v rails. The minimum gpu I would reccomend for you is the 8600 gt but that is on the low end. I suggested the hd 3850 256mb because of its well earned Gold Award given to it my the staff at Hard OCP check the reviews. For $150 it is an outstanding value that will actually run games like Crysis and other dx10 games with decent graphic detail and playable fps.
GL!:D
If you overclock both the E2160 and the 5200+, the E2160 will spank the 5200+. Its easy to OC these Core2 chips, and they can reach around 3Ghz with the stock cooler, just like the 5200+. However, the Core2 chips are faster, clock for clock, than the X2 chips.
exactly, OP will there be any OC'ing going on? If so get the C2D...if not then I vote fore AMD.
HD3850 is a much better card than the 8600GT, I would choose that card even if I need to have a slower AMD CPU.
here what I got figure out to.
CPU
http://www.mwave.com/mwave/viewspec.hmx?scriteria=BA23881
1.8ghz em64t dual core w/1mb x 2 cache 800mhz lga775-pin
$78.25
CASE + PSU (500w ATX12V v2.2)
http://shop1.outpost.com/product/5178426
$74.99 (minus $25 rebate http://image.ak.outpost.com/art/rebates_pdf/5178426_011908.pdf)
MOBO
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
$99.99+ 5.84
HDD ( WD 320gb)
http://www.newegg.com/Product/Product.asp?Item=N82E16822136098
$75.99
GFX (MSI NX8600GT-T2D256E OC GeForce 8600GT 256MB 128-bit GDDR3)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127286
$94.99+ 6.33 (74.99 after rebate)
RAM (G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
http://www.newegg.com/product/product.aspx?item=N82E16820231098
$44.99
I thinking of switch to an AMD x2 to save money and also wait for the HD3600 to come out and see how it goes.
Yeah wait for the HD 3600 for just 4 more days. Not that torturous. Though I would order that case/PSU combo ASAP. The normal price for that combo is $110 and it's being sold for $75 and a $25MIR that drops it down to $50 AR. So buy it!!!
Which is a better choice?
Athlon x2 setup:
-GIGABYTE GA-M57SLI-S4 AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard (99.99 + 6 shiping)
-AMD Athlon 64 X2 4000+ Brisbane 2.1GHz 2 x 512KB L2 Cache Socket AM2 65W Dual-Core Processor ($59.99)
or
Intel Dual core setup
-1.8ghz em64t dual core w/1mb x 2 cache 800mhz lga775-pin ($78)
- GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard
$99.99+ 5.84
Actually, both setups perform about the same at their current stock speeds:
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3112&p=11
If you weren't overclocking, the AMD would be a good choice due to its cheaper price and comparable performance. However, like Enginurd has said, if you OC, and it's very easy to do so, the E2160, it'll outperform even the AMD X2 6000+. So in terms of potential performance and price, the E2160 is a much much better choice.
what is your prediction on the price of that hd3650? And also when it is launched...how fast can anandtech or some of the review website be able to run tests on it. I would love to order it within sometime next week.
According to the first link I listed, about $100. TBH, I don't know.
