Help! AMD Mobo's and Port Multiplier Support
SirKronan
Does anyone know if any of the current Asus AMD motherboards support a port multiplier (such as from Silicon Image) via the eSATA port? Such as the 780g? I would think that all the newer south bridges would support PM for external storage ideally for the HTPC setting. How about the new 785g's? I have an older 780g with eSATA, display port, HDMI, etc, and it's only showing one drive, even though two are connected, and this is via the SteelVine software. Only one drive is showing up there, and it's connected via eSATA.
Will I have better luck if I connect it to one of the actual internal SATA ports via a bracket?
Thanks to anyone who can help me!
Should I have posted this in the HTPC thread maybe? I think I might post it over there, too ... I can't find anything on Google or motherboard specs that say which SB's support PM or not.
I think they are supported by drivers, not the MB. OR the operating system year-of-issue...
or both
So to affirm that is correct, I'd "bing or..." the OS you will be using and the "port multiplier" term
or both
Nope, it's hardware based, sort of like a US hub.
Well, "port multiplier" (scanning wikipedia just then) is a hardware device, which
usually is supported by most most-recent operating system drivers. So both
would be necc. (For instance, I vaguely recall support for port multipliers to
be in the works in the latest ( _8 _9) versions of freebsd).
So the hardware and driver must both exist (afaik) (ianae). As to your question,
I suppose if the port multiplier is in the board rather than an add-on card, the
answer is yes and you can write up a grid of motherboard brands/types which
have that feature.
(triple ianae)
