help abit AN8
DJ_007
ok guys i was upgrading from my slightly older intel rig... so i bought the Abit AN8 32x SLI board.. ok its wierd.. like when i plug it up to power it will come on and work fine ... awesome.. however when it is turned completely off like switch the PSU or unplug the PSU from power to move it i have to unplug the main power connector form the mobo and plug it back in b4 it will turn on again... WTF is wrong with it.. do i need to RMA it for another or what..??? or is there a jumper or somehting im not doing right i mean this is my first SLI and or AMD build .... but i have always been a fan of Abit mobo's...
That is strange. So as long as your power is connected to the wall, you don't have problems?
You have all 3 mobo/PSU connections plugged in?
I must admit to not being familiar with that PSU. :eek:
its not a PSU problem.. because i have also tried my enermax liberty 500 on it and it does the same thing.. and it not necessarilly form the wall but if i just switch the PSU off.... i dunno im RMAing it if someone doesnt have and answer... :(... oh well another week without my puter... :(
Is the CMOS battery out of action? Weird boot/power-up behavior may be due to a dead motherboard battery ...
hmmm i didnt think of that... i just took for granted since its a new board it would be good but there is no tellin how long its been sittiin in a warehouse..
If he's removing power from the board & then when he puts it back in it has still retained his previous BIOS settings it doesn't sound like a bad battery.
Now, if it's losing the BIOS settings as well ...
When you try to boot without having removed the power what does the POST LED say?
If you clear CMOS instead of unplugging/plugging the power does it boot up?
no it was just acting all wierd.. the display was giving stuff that doesnt even corralate to the book... lol... i just RMAd it... lol... another week with no desktop...
Did you post at the Abit-USA forum?
Some of the other codes are known.
I have RMAed my Abit AN8 and the problem still hasn't been resolved. When I try to turn on my machine it shows an "F" on the BIOS LED and after about two minutes the computer turns on. If I shutdown my computer from windows it turns off for about 10 seconds before turning back on.
WOL is disabled and all power options are disabled.
Anyone else have trouble with their AN8?
