Hi guys i would like some information about water cooling. I have a E8400 C2D Gigabyte X48-DS4 mobo and a GTX 470. I want to apply water cooling to both the CPU and GPU. For the GPU i will use a DareDen water block and i need advice on what the main system should be. I mean which water cooling kit to get that is going to be compatible with my CPU(and Corei7) and have enough power to cool the GPU as well. Something silent and efficient if possible. Thanks in advance.
