Help a mobo n00b please!
Well, when I first built my computer I was extremely short on cash and just bought the intel pack and I've been using that mobo for a little while. However, now I have some more cash and my friend needs a cheap mobo so I'm gonna sell him mine. But to do that I need to upgrade first.
I am planning to OC in the future and I don't need SLi or crossfire. The p35 boards look tempting but I'm not sure which ones suit better needs. I've been looking at the DS3R and the DS3L and I've looked at the IP35 Pro's and the P5K deluxe. Overall, I'm not really sure where to start. I have about 100-150$ to spend (lower is always a plus though). Suggestions?
Rig in signature. Thanks. :)
Well, if you're not running RAID or need more than 4 SATA connections, I'd probably just go with the DS3L as it is cheaper. It's a good OCer, and has a pretty wide support base. The DS3R has RAID built into the southbridge, but like I said, if you don't need it (or firewire, IIRC), the DS3L is some $30 cheaper.
The Abit and Asus are good boards too, but the features might be overkill for your componenets....you can save yourself $50 without them.
