Help, 9800GTX Display Problems
RoosterUSMC
I just got an EVGA 9800GTX and Ive installed the latest driver on Nvidias site (174.74) and when I reboot into both XP32 or Vista64 the image quality is messed up. It looks like its running in lower than 32bit mode. Also when I select my resolution 1900x1200 its off center and I cant adjust it. With my old card it auto adjusted to fit my LCD (LG246WP). Its the same way in a game that I tried.
When I uninstall the drivers and boot into whichever OS the image quality looks good, the way it was before and when I set the resolution it adjusts fine.
Any thoughts on what this could be?
No luck. Tried the drivers from the CD 174.40, drivers from their site 174.74, and beta drivers 174.93
What type of monitor are you connecting to and how are you connecting to it (DVI, HDMI, VGA)?
LG L246WP LCD set to digital, its just using the regular cable thats on the LCD no adpater. I think thats DVI right? But my on screen LCD settings are set to HDMI the only other setting RGB gives no signal. Its the same way I had it setup with my 8800GTS.
Another thing Ive noticed is that with the drivers installed it using a different color scheme where before it showed RGB individual values it now just says color 100. When I uninstall the drivers the display goes back to the way it was on my 8800.
I had the same problem on my L246WP and new 9800GTX. Thanks for that link! Fixed it in a jiffy.
