WickedWeasel
- Jul 13, 2004
The new HSFs are getting larger and heavier. I was wondering if the huge increase in weight is causing the HSF to detach from the mount at a minute level which might impact its effectiveness.
Test 1 Vertical Mobo and Case, HSF Sideways
Computer sitting as usual, motherboard is vertical and the HSF is horizonal.
What are the Idle and Load temps?
Test 2 Horizontal Mobo and Case, HSF Upright
Computer is lying on the side. The motherboard is horizontal and the HSF is upright with its full weight over the mount.
Tests are done with the computer in the same general area.
I would like some data on this. Please post if you have done the tests. Please provide information as to the type of HSF, fan speed, case, number of case fans, etc...
I'm thinking of getting the scythe infinity, but with the great weight, I was wondering if tying strings to support its weight might help? If test 1 and test 2 yield the same results, then I won't need to use the strings, but might still add them just to prevent damage when the case is moved around.
