Forum's "slipping" because it's been three hours since your post, on a Sunday might mind you, and you haven't received an answer? Yeah... Ok, not even gonna touch that one. Search button works wonders tho, maybe your common sense is slipping tho.
Anyway, if you're into clean audio and online gaming your best bet is to forego most of the crappy peripheral brand headsets and get yourself some decent headphones, by far. For $50 the Samson SR850 would be right up your alley, very detailed with a big sound stage for positional cues in games. Most crap headsets for twice as much won't sound half as nice.
Add a $5 Zalmam clip on mic and you're done; or if you really need a boom mic or feel like splurging then spend an extra $30 on an Antlion ModMic. It's a bit overpriced but the mounting system's pretty clever (yay magnets) and the mic itself picks up far less background noise than the omni directional Zalman.
There's a Superlux version of the Samsons that differs a little in design but sounds the same basically, one or the other might be cheaper at any given time. I forget the model though, I'm sure it's in a recent thread, or two or three. Then again the boards are slipping so maybe not.![]()
