Headphone Recommendations?
Xee
I'm looking to get my brother a decent pair of headphones for his Iriver H-120 mp3 player as an X-mas gift. I don't want to go cheap but then again, don't want to go nuts either. I guess I'd be willing to spend up to $150-$200 tops. Here are the requirements:
1. No monitoring headphones! - These are more for profesional use and won't function well off the power mp3 players provide.
2. Noise-cancellation - You know, the stuff they have in headphones for people who travel in planes a lot. He spends a lot of time in the computer labs at his school and says they're noisy as hell. Obviously, this means they can't be earbuds.
3. Compact - Something with a folding design that he can tuck away in his backpack.
4. Case - Obviously, a case for them.
Well, thanks in advance. Also, f anyone can point me in the direction of a forum that caters to these types of question, I'd greatly appreciate this.
Xee said:
Umm . . . this has nothing to do with a computer.
None the less, that really is the most applicable section.
I would recommend the Sony MDR-V6 or the MDR-7506 (they are the exact same except the 7506 has gold plated plugs). The V6 can usually be found for around $60 and the 7506 can usually be found for under $100.
They don’t have “noise cancellation” but they are closed headphones and do a great job of containing the sound.
Thanks for the recommendation.
As for the post, I just figured it'd be off-topic there. Think you can move it?
Moved to Comp. Audio
Also I'd suggest Sony EX-71's (you can get them for about 45) they are in-ear type, sound pretty good too.
My Fiancee jacked mine for her iriver...
