HDMI Spec Updated to 1.4
Terry Olaes
I Used to be the [H] News Guy
Ars Technica took a look at the new HDMI spec, 1.4, and didn’t like the added complexity that was added to the system. Check out the article for the details on the new capabilities introduced by the specification, including support for 3D formats and even dual-stream 1080p. An automotive connection system was also added to the spec, making in-car HD a distinct possibility.
Marketing hyperbole aside, the new specification now includes a total of 5 different cable types: standard, "high-speed"—which handles the higher data rates for 3D and digital cinema resolution, Ethernet-capable versions of both of the previous two, and an automotive-specific variant. Further, as Venuti said, in addition to the standard HDMI port and the already small mini-HDMI port, the spec adds a 19-pin micro-HDMI variant that is compatible with up to 1080p resolutions for portable devices.
Now in stock: Monster Cable XXL Ultra Gold Edition HDMI 1.4 cables, only $199.99 for 1 meter!
Well, I'm sticking with 1.3, can't really do much when 1.3 cables was installed in the walls and made permanent :) lol
I like the idea of having a consumer interface that supports 4K, but I don't like the idea that we won't see distribution of 4K content for 10-15 years (maybe longer?).
You know the purpose of HDMI was to simplify the cable mess behind entertainment system. Should have know that they would even complicate simplicity. Now you are going to have a cable mess of HDMI cables that are meant to eliminate cable mess.
Except HDMI is quickly becoming (or in most cases already is) an "all-in-one" cable. This eliminates the need for separate cables for audio, video, and soon it seems, networking. The goal appears to be to have only one cable (other than power) coming from each component. Until all of that becomes wireless, this is the best we can hope for in terms of minimizing cable mess.
Also, with all the new specifications, it isn't as if you're going to need to use all of the different cable types. There will just be different choices for different uses.
Just need some clarification.
1. Will there be just one HDMI cable with many more capabilities?
2. Will there be Many HDMI cable variants with different capabilities?
I hope #2 is not the case.
I have already run into a few proprietary HDMI cables for projectors.
They look very similar to HDMI cables except for a very minor way the connectors are keyed.
There is nothing ubiquitous or "all-in-one" about a cable that looks exactly what you need but isn't.
Why not include power as well?
Do they teach common sense at Engineering schools?
They didn't at mine. I had to learn that on my own.
Oh well there always be Intel Pentium IV and Marchitecture to justify this kind of decisions. I wouldn't liked being in those engineers boots.
Care to elaborate on this? You didn't actually explain anything.
Including internet is a bizarre move, just to save an extra wire or port *if* all of your connected devices were ethernet-capable. Is this what they intend, for all devices to be connected to the internet, and if so, to what end? Is it a DRM thing? Software updates?
This is also unsafe-- effectively using HDMI as a conduit for internet traffic that can't be effectively detected, traced or blocked.
HDMI versions are backward compatible.
There are 2 things I don't like about HDMI.
1. You need very special tools to attach the connector to the cables
2. the connector is flimsy and there isn't a positive latching mechanism.
Basically the same could be said for CAT5, and even though there is a latching mechanism, they tend to break off after what seems like very little overall use.
Wikipedia.org said:
Version 1.4 was officially anounced on 28 May, 2009.[56] This version increases the maximum resolution to 4K x 2K, allows 100 Mb/s Ethernet connection between the two connected devices, and introduces Audio Return Channel, 3D Over HDMI, a new Micro HDMI Connector, Expanded Support For Color Spaces and Automotive Connection System.[56]
Some nice new features.
I think display port could have easily have handled this without creating a new spec.
New useful features is true. But wasn't hdmi in the beginning supposed to be one cable only to simplify connecting devices and cabling, now they've got many different types of connectors and standards which may confuse. And where did they say 1.4 is backwards compatible with the older ones? I red somewhere that it isn't, the plug is different, hopefully I'm wrong.
It says right in the quote that the standard HDMI connection is still included in the spec.
I honestly don't know why people are making such a big deal out of this. More robust = good as far as I'm concerned.
This is why I refuse to go HDMI until they settle the technology. They update the format every half a year or so. How do they expect people to enjoy their purchase of technology that expires within half a year? Especially when receiver producers, except a few, don't keep up? Once they finally say "Ok, we have a great version of this connector and we will keep it thusly for a while", then I will be happy to go HDMI. But that won't be for a long long long long time.
Backward compatability? You don't need to keep upgrading your equipment to use these new cable specs. In fact, no content even exists right now to take full advantage of HDMI 1.3 Deep Color, let alone HDMI 1.4 3D and dual-stream.
Remember when Sony was originally pitching dual hdmi outputs on the PS3 ? Seems like they were ahead of themselves by a few years :p
Also, Ethernet capability on the HDMI cable ? That's semi-interesting, assuming TVs/Receivers start to use that, and then we'll see TVs with Wifi built in o_O That would be cool.
As many have noted, it's backward compatible.
Very much in the same way that you can use pcie 1.0 devices on a pcie 2.0 motherboard.
QFT.
I could never go back to component, the cleaner wiring alone makes HDMI completely worth it. My home theater used to be a rats nest of cables, now its clean clean clean. Only thing with component and RCA audio cables is my Wii, everything else has a single cord running out the back. Very nice.
theyre not going to settle on a standard cable for the next 20 years. the problem right now is display technology literally exploding. oled, 3D, and the countless other enhancements that keep popping up for tv's keeps changing the demand for the cable. they should try to make a more-future proof cable though, which is why displayport is intriguing.
