HDMI socket 939 motherboard?
[CaM]Spoon
Hi,
I have a home theater where I have a network computer in basement and its networked to my xbox360 which puts the signal on my HDTV with media center. Strangly my xbox360 broke.. dont even play games on it, its mostly used for the media center. Since I dont use it for games (they all stink) I decided to bring the computer into my hometheater area. Only problem is I need to connect it with HDMI.
Does anyone know If theres a HDMI motherboard out there that uses socket 939?
I dont wanna upgrade my cpu since I have a althlon 64 3500 which is pretty much perfect for hd movies, and im not looking to spend alot of money becuase i already want to build a gaming computer also.
Any help is appricated.
i was looking at this one http://www.abit-usa.com/products/mb/techspec.php?categories=1&model=324
Its so perfect but its for intel cpus. Other then that its everything im looking for.
Sir you may want to consider trading your 939 for a p4 478 on the for sale trade section.
If its so perfect for your needs it seems like it wouldnt be to hard to find some one willing to trade. There are alot of p4 on there.
If you aren't looking to spend a lot of money, I would do a little looking around for a new graphics card that has HDMI. They aren't that expensive and should work for what you need it to do.
SoulMan901
I was considering that. But cheapest one is a x1600pro for $169CDN
But even looking at the prices of those HDMI motherboards is actually more expensive. That Abit is 225 dollers. I just thought getting the motherboard with it is overall better so i can upgrade video card when ever i want if i feel like playing some games on my HDTV.
Video still will go through the motherboards HDMI but use the PCI-E video cards power?
Might not want to trade for a P4, that board requires a yonah or merom, so either a mobile Core Duo or mobile Core 2 Duo is what you want.
How you know what the name is of the cpu?
And i was looking at reviews of that motherboard and what a shame that it doesnt have a pci-e slot. What the hell you use a pci-e x1 slot for anyway? Would have been nice to throw in a decent video card so i can play some games on my HDTV.
Thought the motherboard was perfect until now.. Wish there was more HDMI motherboards out there in micro size. Really want one.
There's another version of that motherboard that has C2D LGA775 support. That should be significantly cheaper than the s479 board. If it's more than $100, I'd be surprised.
any graphics card with DVI card will work, just get a DVI-->HDMI cable. ;)
Won't get sound out of it though. The newer HDMI video cards have sound input headers from what I've heard. This is the cheapest solution as long as you run your own sound to your TV.
Oh, I just thought the OP was looking for video only since he really wasn't specific. He also mentioned the word 'home theater' so I would assume he would be using a nice receiver with surround sound instead of tinny speakers on a tv set. :p
Yes of course I have a reciever For audio im gonna use the optical of course which that motherboard does have.
Oh and I think Using a DVI to HDMI butchers the quality if im not mistaken.
DVI to HDMI is digital to digital with no conversion.. the quality is top notch as good as you are going to get.
I was reading up on it and I found that you are right and theres no difference if I use the converter. The only thing that wont work is a HDDVD player. The HDMI has a decoder or somehting inside that can play the HDDVDs. Apparently if I buy the Xbox360 HDDVD player it will in fact still work without HDMI. So i guess everything works out and ill use my old motherboard with cpu.
Just got to rebuy some cards though since my motherboard was a shuttle xpc which only has one agp and one pci :/
I'm using the Xbox 360 HDDVD player with DVI. As long as you have a HDCP certified monitor and graphics card, you are all set. If you are using an analog connector or non-HDCP certified components, don't count on it working properly. The HDDVD software is flaky.
With the ABit IL-90 motherboard there is NO PCI-E slot, only pci so don't expect to put another graphics card in unless its the old school PCI
