If there is a physical problem with the hard drive, then you need to get a new HDD because the old one is failing.So if it is not does that mean i have to get another hdd?
If i have a hdd error when i start up my computer build for the first time can i just buy a windows xp disc and reformat it?
What happened was i put the hdd into a computer and it saved windows on it so i tried to format it so i could put it in the comp i am building and after it was done i restarted the comp and just said that there was an error and i cant go any further than that just to the error sign so i was wondering if i could just buy another windows then format the whole thing from there?
I dont have any windows xp CD so i should just put the hdd in the comp i am building switch it on and install a new windows xp with my drivers?
