I just bought a raidmax smiloden case, however they spell it, anyways the hdd led wire that is in the case to the mobo is sliced, will the pc still work without it? sorry in advance for asking a dumb question.
The wires are the same, but the connector is sometimes different. You can fix the cable...just strip off the casing a little bit and twist them back together and then cover it with electrical tape. It should work.
