All was well till a couple of days ago. I opened up the casing to change CD-RW drive. I changed the drive, blew around some compressed air to dust things off and closed the case. When I powered on, the Hard Disk LED did not flicker as usual. Instead, it stayed on (solid, no flicker). Now the light stays on from the time the Comp is powered on till it's powered off.
I was worried thinking the HDD was ALWAYS spinning. But I ruled that out by removing all HDD connections from the Mobo except for the small HDD LED wire. The LED still came on and stayed on just as before. So, this means that regardless of the HDD connection, the HDD LED comes on if its wire is connected to the Mobo.
Can anyone explain what might be causing this and how I might correct the problem? Could it be a motherboard issue?
My system contains:
Intel P4 3.6GHz proc
Intel D915GAV motherboard
Maxtor 120GB SATA HDD
XP-90C heatsink with Delta fan (fixed 2 months ago).
Thanks.
My system contains:
Thanks.
