HDD issue with mobo?
Epedemic
Well, I originally had an Asus p5w dh deluxe and a coolermaster mini r120 cooler and upgraded to a gigabyte ud3p and arctic freezer cooler pro 7 today. Everything is fine and I expected to get the usual driver issues but, I haven't been able to figure out why I cannot access one of my HDDs. I have 2 HDDs, 1 74 gb and 1 320 gb. I boot from the 74 gb.
To get to the issue, everytime I restart or boot up the pc, chkdsk runs on the 320 gb hdd and the file format is NTFS and everything is fine except once the chkdsk is over and everything is fine, it says "the second ntfs boot sector is unwriteable" and when I go to the properties of the E drive, the file system is "raw". I didn't install or do anything to my HDDs besides just upgrade the mobo and cooler. everything is the same as it was before, although i'm thinking it there was a setting on my old mobo that probably made the difference. Any help is appreciated.
Did you reinstall Windows when you switched boards? If not, then you should do so.
Is that normal when switching motherboards, to reinstall windows? Sorry kind of new to some computer aspects.
Try downloading the disk checking tools from whoever manufactured the drive you're having trouble with and run them to see if the drive is functioning correctly. If a reinstall didn't fix it, then the drive itself may be faulty.
Well, I just decided to just go ahead and reformat the drive, since that usually works. There is nothing wrong with the hard drive, i'm just not sure why i got those errors. Lost a lot but whatever, I can live without some of the stuff.
Although my main problem now is my cpu doesn't want to overclock at all... on my p5w board, I got it up to 3.11 ghz from 2.40. Now on my GA UD3P board, it doesn't want to go up not even by 4 hertz. I have the CPU VCore set to auto, and it shows as 1.325 so I'm not sure why it won't let me overclock at all when I hit 3.11 ghz on my asus with np at all.
Maybe your power supply isn't doing so well? What is it, and what are your system specs?
I got it to work but this is weird. I had to use a software application (easy tune) in order to get it to overclock which is strange. I think my PSU is doing fine.
PSU: Thermaltake Toughpower 750w
CPU: e6600 @ 3.35 ghz
Mobo: gigabyte ud3p
RAM: 2gb Corsair
video card: 2x diamond 4850 in CF
OS: xp sp 3
HDD: 1 320 gb, 1 74 gb(10k rpm)
Case: Coolermaster stacker 830
My only problems I have now are just mouse lag when playing games in full screen and my x-fi sound card doesn't get recognized. I did adjust my video card settings to something lower in regards to the mouse lag but still no go. windowed mode doesn't give any mouse lag.
