HDD "clicking" sound
ann0yanc3
I just bought a 750GB Seagate drive. I installed it no probs, but as it started formatting, I noticed a clicking type of sound. The clicking isn't all the time. It's random. Sorta sounds like metal grinding for a short period of time, but not that intense. Hard to explain. Drive seems to work fine, and doesn't making the sound too often. I also have another 500GB Seagate in the system and it has never made a sound. hmm...
Anyone ever heard of this kind of thing? Bad drive, or just a "normal" sound?
sign of a dive going bad, the gaps will get shorter between the clicks then eventually the drive will die.
RMA the drive.
Agreed. I had similiar issues with a Seagate 7200.10 320gb. When I called Seagate and mentioned that the clicking sounds (sort of a loud single metallic click) occur intermittently in the middle of useage, they recommended replacement and I went with it. The replacement drive they sent out doesn't make any clicking sounds and is currently performing great. Definitely RMA it.
yes for sure. if you're getting the infamous 'click of death' from your HDD backup ASAP to DVD, spare drive, etc. and call seagate.
I always assumed this was normal as my last PC did it and this one has been doing it for like two years..oops! lol
Haha, omg, my raptor has been doing this for a while, i just taught it was normal becus of the speed, it might be louder, guess ill have to freshen up on the WD warranty rules.
I have a raptor 35gig ADFD and when it's thrashing it make clicking sounds, I thought this is normal for raptor drives due to the 10k rpm?:confused: If not, I may have to throw up my RMA for the WD Raptor too...
Hard clicking, or small lil clicks? Hard clicking is bad, and I'm guessing the small lil clicks are, too, lol. Though, hard clicking is a sign of a drive going bad. The small lil clicks are just the noise seagates like to make when seeking. DL and run HD Tune, and after the speed test, it'll do a seek test... during that 2nd test, you should hear the "noise" I speak of.
Both my raptors make that noise; very fast clicking noises at LOAD. So I think it is very normal to have some sounds when the drive is at work. I think you need to record this sound so we can all compare it and see exactly what's going on before half the people on the forum RMA their raptors :rolleyes:
The small ticking noise made when the drive is seeking isn't usually too loud, btw.
