I bought a Samsung Spinpoint OEM from newegg in May. I partitioned it so Vista and programs were on their own partition and another partition had just my files (music, photos, etc). Recently I had been hearing just a single click every once in a while while trying to access something on the C:\ partition, like a file on the desktop or something. Just that though, one click, then nothing else at all. I figured it might be a bad sector or something. It hadn't gotten worse, or any more frequent so I figured it wasn't anything too pressing. Also, since it was only that partition that would click, never the partition with data, I didn't think it was the entire drive that had a problem.
This morning though, I went to fire up my rig and while the loading bar for Vista was going, I kept hearing a click about every 10 seconds or so. I restarted, chose safe mode, and it hung up while loading 'windows\system32\drivers\crcdisk.sys'. So it seems to me that this partition is screwed up somehow. Am I right, or should I be worried about the entire disk? Is there some other kind of diagnostics I can run to figure out the problem, or even fix the problem?
