96redformula
- Oct 29, 2005
OP should edit his post. The 6970s are $370.
So which brand would be the best one to get, the Gigabyte with the 3 years warranty, or the XFX at $10 more with lifetime?
I was planning on going with ASUS since they usually have a better design (even reference). The 6870's cooler springs to mind. But, without ASUS listed, I'll be buying XFX I guess.OP should edit his post. The 6970s are $370.
Will you be using the card in 3 years? How old is the card you are replacing?
How late were they on the 6870's? I think they were available at launch.Why ASUS is always fashionably late to the party?
Ok, someone give me a AMD crash course real quick.. I haven't owned AMD in a while.
What is the most reputable brand, best RMA support, tolerance for custom heat sinks and overclocking without voiding warranty, etc.? e.g. for Nvidia many would arguably say EVGA.
Sapphire isn't exactly known for great service.sapphire
I'm sad.
Checking other e-tailers hoping to see them show up soon.
The night is young!
I have one in my cart waiting for numbers, replacing a 5970 for eyefinity.
What if they sell out before NDA lifts! What the hell.Prices are telling me to buy now, logic is telling me to wait for the [H]ard|OCP review at 12:01 PST. Damn you logic!
Newegg should have over 100+ XFX 6970's in stock.wow. xfx 6970 already gone and xfx 6950's price jacked to 313.
I just checked.
Only the Sapphire card gives a Mini-DP to DP adapter. It was frustrating not to get one when I bought the 6870.
They seem to randomly charge people $15 RMA fees.
XFX is probably hands down the best for customer service + lifetime warranty.
I'm questionable about buying XFX though, I remember hearing a lot of bad things about their quality. I can't cite any sources on that, I might be full of shit.
edit;
wtf you bought a card before it was even benched?
With less stream processors on the 6970 then the 5870 it looks like AMD must have made some huge architectural changes..
Not doing anything till I see some reputable reviews..
My luck they will be gone by then..
