(I'm not quite sure where to post this.)
I have a Z87 Haswell PC with a 4770k that I am setting up. Display is a U2711, connecting over dual-link DVI. For some reason, max resolution (Windows 8) is limited to 1680x1050 using the in-chip HD Graphics 4600 core. It will not allow higher resolutions. W8 seems to be detecting the display as the U2711, and I do have the latest IGFX drivers installed. The cable is definitely DL DVI; I use the same cable to connect a different computer (GTX580) to this monitor at 2560x1440 without issues.
Is there a limitation in the Intel GPU that keeps my resolution low? Is there something else I can do?
