another-user
- Dec 27, 2006
from what little i could find on it, its supposed to be out late Jan. and be priced some where around 200.00.
we shall see how true that is.
Powercolor came out with the 3850 AGP. DX10.1 card! Too bad its not the 3870.
http://www.powercolor.com/Global/pro...ProductID=1730
Availability in January, pending driver release.
And maybe more powerful agp cards from ati coming out in the future?
If you have an agp Athlon 64 3500+, Athlon X2, Intel P4 3.2 Ghz or better system the HD3850 will be an great upgrade and will give your aging PC new life.
Ignore PC elitists, and the agp naysayers.
And the idea of replacing a motherboard without doing a clean install makes me cry. Seriously, I've had the pleasure of fixing this issue on a few occasion from people that thought they were so smart. The driver/file/program/registry issues that occur doing this can't be accounted for. Different motherboard chipsets rarely play nice together. Then customers complain, "why is my new PC so slow," or "why is my new PC full of errors."
If you would listen, your rig is so CPU limited that putting in a larger GFX card will hardly even help at all.
If you are on AGP, upgrade to PCIE cheaply. If you have to use a LGA775 Cedar mill and a PCI-E X850 than thats what you have to do man...
I don't understand why some people would suggest AGP users to upgrade to PCI-E now, PCI-E is dead, PCI-E 2.0 is here already
So, this confirms what the Inq said.....Interesting..
Unlikely. The 3850 will either max out AGP's bandwidth or come close to it. Anything faster than that and you're going to see some seriously diminishing returns. I wouldn't be surprised if we see more AGP cards down the road, but they won't be in the performance segment, they'll be mid-ranged, then low-end, then the format will finally "die", probably more than a decade after most HardOCP denizens held its official funeral![]()
Just a reminder with regard to what the 1950 Pro AGP accomplished:
http://www.tomshardware.com/2007/02/01/agp-platform-analysis/page10.html
According to this review, the 1950 Pro AGP made an appreciable difference even on an Athlon 2500, even more on a 3400 (single cores).
I would conjecture that for some, the 3850 variant would be a viable alternative, provided the addition of the Realto chip doesn't increase the cost more than $20-$30.
Just a thought...
I saw in a benchmark that someone simulated the AGP (capping the PCI-E to 4x) and only the 8800GTX showed slighly decrease in performance while the other cards stayed the same, after all, the operations that most saturated the bandwidth are the texture reads and fetches, and none of the currently ATi hardware have such great deal of texture power like the GeForce 8 do because ATi hardware relies more on shader performance. So the only bottleneck that the Radeon HD 3850 may face is a CPU bottleneck.
Hello,
PCI Express Implementation Encoded Data Rate Unencoded Data Rate
x1 5 Gbps 4 Gbps (500 MB/sec)
x4 20 Gbps 16 Gbps (2 GB/sec)
x8 40 Gbps 32 Gbps (4 GB/sec)
x16 80 Gbps 64 Gbps (8 GB/sec)
AGP8X 2.1 GB/sec = peak 32-bit transfer rate
source: http://www.dell.com/content/topics/global.aspx/vectors/en/2004_pciexpress?c=us&l=en&s=corp
Didn't PCI-E come out 4 or 5 years ago?
Why does it take so long??Edit:
Also a Mod at Anandtech spoke with a Sales Rep for Sapphire and they said their card will be out Mid-February.
I would realy like to upgrade my AGP slot one last time with this card. to bad Nvidia isn't makeing one last AGP card for the 8xxx version. those 3dmark scores are amazing. will be a great update from my 6800gt.![]()
