Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Nope. Odds are something else just happened to request data from the disk at that point. If you run the test again you'll likely get a different result.
the rattle noise that i heard that made me run hd tach in the first place was actually comming from my case. i just ran hd tach again and just like before the huge dip shows up in the exact same spot.
WD Diagnostics didnt detect any problems. This is the HD Tune results, i ran it a few times and get about the same results every time.
I believe the dip in HD Tach matches up to the dip between the 30-35% mark in HD Tune.
