legoman666
- Dec 21, 2003
I think I just got a boner...
http://www.anandtech.com/video/showdoc.aspx?i=3750&p=2
2gb ram, otherwise pretty much the same as a vanilla 5870.
A 5970 with 6DP and 4GB of memory would make more sense imo. That should have the grunt to do eye infinity with 6 displays. It always struck me that the current 5970 was pretty memory bound - I mean the thing is designed for eye infinity, yet it is effectively a 1GB card (as memory not shared). That doesn't sound a lot for the sort of res eye infinity allows.
What's display-port monitor availability like in the US now?
What we know for sure is that this is enough of a card for steady 70-80 FPS in World of Warcraft.
..In the Tauren starting zone![]()
Putting two gpus As well as 4gbs of memory would be a huge card. A 5970 board size is barely less than the maximum size ATX allows with its spec. Doubling the amount of memory takes extra board space.
Now ATI could do a dual pcb, but that adds to the cost, and is much harder to cool.
Furthermore the 5970 has to be run at lower clock speeds, with the best binned chips to keep under 300watts. A single 5870 has a tdp of 188 watts, if you double the memory you are also adding more heat to that 188 watts (unless you bin the 5870 eyefinity chips so that you are using chips that require less voltage). And you want double that 188 watts to be on a single pcb.
Crossfire two 5870 E6 is far more practical from a manufacturing standpoint. You don't have to make super large boards for two cards is just liking having two pcbs. Furthermore you have double the physical area to exhaust the hot air out of the case. Two 200w cards are far easier to cool than 1 400 watt card.
And with ATI as currently done you still need to run Eyefinity from the top card display connections exclusively. You can't connect some of the display connect to the top card and some to the bottom card. Thus you need the top card to have 6 connections. That is why ATI is releasing 5870 E6.
There wouldn't be more memory chips - number of chips is defined mostly by bus width as I understand it, just each memory chip would be twice the size - it would just look and work like any other 5970 only with twice the memory. The only difference would be a few watts extra power as the higher density chips might take a little more, and perhaps slightly different memory timing.
There are other advantages over two 5870's - the 5970 which is effectively xfire on one card works much better with eye infinity then xfire with two separate cards so big advantage there.
Oh, if you effectively do want 2*5870 on one card just saw this today, asus have gone potty and produced this monster:
http://www.xtremesystems.org/forums/showthread.php?t=245988
Probably costs a fortune but it's very [H]![]()
A quote from the Anandtech article...
"The 5870E6 will come with 2 mini-DP to DP dongles, 2 mini-DP to single-link DVI dongles, and a single mini-DP to HDMI dongle"
So am I to understand, a 30 inch monitor that needs a dual-link DVI will not be able to use any of the supplied dongles with this card?
