I picked up a Visiontek HD 4850 to upgrade my daughter's SFF PC. Will this card be too hot? The case is an Aspire Qpack. I also have a Lian Li V300B that I'll probably use instead. However, I'd like to know whether this card will be putting too much heat for a SFF PC. What do you all think? Do you know of a good aftermarket 2 slot heatsink that'll vent heat out the back?
Thanks
Thanks
