First off, here are my system specs
Abit ip-35
E6750 at stock speed
4gb G. SKill PIe series ddr2-800
Antec Earthwatts 500w
WD Caviar Black 640gb HD
So I bought a XFX 4890 a little over a month ago to upgrade from my 1950xt and immediately noticed a high pitched ringing that turned into a much more audible squeal when running more graphic intensive games. After doing some research, I found that the squealing often occurs when the PSU is not powerful enough to run the video card, though everything I read said that my PSU should have no problems.
Fast forward to yesterday. When I started up, my monitor turned like like usual, showed the post screeen, showed the windows Vista loading screen, but once start was just about to finish, the LCD went into standby mode and said there was no signal. I reseated the video Card twice, checked to make sure the ram was completely in and still nothing. I was able to log into and start windows using Windows Safe mode. Making sure it was just the card I put my old one back in and everything was fine.
XFX wants me put it into another system to see if it is just my PSU. but none of my friends have builds that would allow me to do this (Most aren't very tech savy). Any advice?
Abit ip-35
