Have I reached the Sata 2 cap?
Igg
I was running 2X Samsung PM810 (128GB, 128k stripe size) and was getting around ~500MB/s read & write.
This is running on an INTEL ICH10R MSI Big Bang X58.
Since I know that RAID 0 scale pretty linearily with SSD, adding a 3rd should net me around 750?
Long story short. I'm only getting this.
128k size also btw.
I'm trying to avoid buying a new pair of m4 sata 3 6gb/s for a new z68 build since I have 3 perfectly working drives here that I can RAID 0 x3 with 300GB usable capacity with 20% empty space on each drive for wear leveling.
Yes it appears so since the max would be around the 600MB/s range...then again those are just large read/writes
I need large reads mostly as I five box wow. so there's always a large amount of data to be read when everything is multiplied 5x
Looks more like the controller itself is reaching it's max bandwidth. Not exactly sure how the X58 assigns pci-e lanes to it's SATA ports but you might be able to move some cables around and get them split up so they're not sharing lanes. Someone else should know more than me.
Well, the theoretical maximum of 6Gbps should be 715,26 MB/s so I'd say you hit the ceiling.
Also, I doubt the OS is reading identical data 5 times at the same time, since that's what would happen if you multibox and do everything in sync. If data has just been read and is requested again, I think even Windows manages to provide that from some buffer cache.
And finally, loading in WoW is not exactly very disk intensive. Switching to an instance keeps my HD LED lit far less than permanent. And as I said, it's not supposed to read 5 times straight from disk anyway.
