If it has solder instead of thermal paste under the IHS i might consider an upgrade.
I'm in the same boat, i might consider an upgrade if the IHS is soldered.If it has solder instead of thermal paste under the IHS i might consider an upgrade...that 7%ish increase goes up quite a bit if we can actually harness the full OC potential without delidding.
I'm thinking haswell might be a nice upgrade from my 1090T (gaming) setup. Will I be able to re-use my 32G of ddr3?
I really need a MC deal on haswell before I jump.
That's interesting, it would explain all the rumors about IB-E being cancelled. I thought it was odd that their extreme platform was lagging behind the mainstream platform. The only downside is no drop-in upgrades for Sandy Bridge E users.
Is your DDR3 1.5V or lower?
Is there any info about 6-core CPUs?
I'm curious, short of going Xeon workstation is it going to be impossible to get a chip that doesn't have a GPU (which from my limited understanding - either software or drivers won't let you use if you're using a real man's video card aka pretty much anything over 40 USD)
Only that none will be on lga1150. It's not clear if SB-E or Haswell-E will be the next lga2011 chip. If its Haswell-E this will likely need a new socket since Haswell-E will use DDR4.
When do we think Haswell-E will land and at what sort of price? 2nd to best CPU at c£500?
You can use the integrated GPU to drive extra monitors alongside your dedicated GPU. I'm driving 2 monitors from my GTX480 as well as 2 extra monitors from the 2600 in my work PC and it's fantastic.I have both Nvidia and Intel graphic drivers installed...windows is smart enough to know what it needs to do. You need to force the IGP to always be on in the bios but overall it's really straightforward.
Having said that, I am also concerned that the current batch of GPUs have been around for over a year???
I've been out of the loop for sometime (last machine died back in the mid-2000s)...but back then I am fairly sure it common to see a GPU every 12 months or so with interim refreshes too.
Have things slowed down a bit on the GPU side while sockets seem to be churning faster (new Intel socket every 24 months)
I'm Hard Gawd but a little rusty![]()
Man, computer manufacturing/buying trends must really be changing.2 Dutch websites are listing the 4770k for sale, though not currently in stock.
1st store is MaxICT who are listing it at 330 Euro ($424.88)
2nd store is TakeItNow who are listing it at Euro 350 ($450.63)
In the Netherlands an I7 3770k currently retails for Euro 316 ($406.85).
http://www.tomshardware.com/news/intel-Haswell-Flagship-TakeItNow-MaxICT,21594.html
Computer buying trends are changing quite rapidly. I would assume this is merely a correction by the industry(s) to try to compensate a bit.
You mean nForce2. Yes, I remember the Abit nf7 boards. .... that was a Golden era indeed!! I am using a Soltek (remember them?) Golden Flame nForce2 system to type this. And it's my top end systemSo the pricing of the 4770k is, by and large, in line with the pricing of the current 3770k.
So would you say the GPU sector has slowed a little (possibly intentionally)?
Like I said, my last machine was a Northwood CPU on an Abit (remember them?) IC7-MAXIIII'm struggling to remember the GPUs I had though, BFG 6800Ultra comes to mind and I also had a Sapphire ATI card, possibly a 9800XT?
Before that I had an Athlon setup also on an Abit board I think (Geforce 2 IIRC).
A golden era indeed!
http://www.fudzilla.com/home/item/30657-msi-showcases-z87-motherboard
MSI showcases Z87 motherboard
Apparantly it's not coated right now so it looks like a 90's mobo, but is that a bad thing? I like that old BX6 / BH6 look!
The small controller chip is on the CPU the mosfets and coils will still be on the motherboard.Wait, I still see a pretty robust VRM array on those MoBos... Isn't the VRM all on the CPU with Haswell?
That's an expensive chip to have so much of all resources be wasted on a GPU that ultimately will probably be pretty useless most of the time to most of the people buying it.
The overwhelming majority of these chips will be in laptops. If you consider that nearly 3/4 of all PCs sold are laptops, then the die space and resources wasted on the on-die GPU make far more sense.
Okay, that make more sense then.
But still, say no to Intel graphics, seriously. Just say no, unless its in a switchover so you can get a real video card when you need it (which is pretty much for any game that isn't WOW or Skyrim or Angry Birds).
Intel graphics is fine for general usage, good for backup purposes, and have been getting better for gaming. Still can't match AMD's APUs though.
i was considering buying the i3-3225. Should I just go ahead and buy it, or wait until more news about Haswell?
Exactly. In laptops it's great for a switchover where you switch over it any time you do anything that requires an actual video card. When you don't need a real video card you can use the Intel and have low power consumption.
