Just got a great deal on a pair of 980's so I need to upgrade my current i7 950 system, not sure if I should go haswell-e or not..
Would like to buy a combo deal at microcenter which is 1 mile from my house.
will purchase RAM and HSF online most likely
I am also planning on using my i7 950, mobo, and ram for a HTPC build, but I will be re-using my case, power supply, SSD, optical drive, and storage drives for my new build.
--- Mainly gaming, then photo editing with photoshop/lightroom
--- 700-900
--- USA, and Yes, microcenter is walking distance
4) What exact parts do you need for that budget?
--- CPU MOBO RAM COOLER
--- SeaSonic SS-1050XM (should be fine for SLI 980s?) Full Tower Corsair 800D case, samsung SSD, assorted WD Green storage drives, optical drive
6) Will you be overclocking?
--- Absolutely, would prefer a very easy overclock GUI
Will get getting a 4K G-Sync, or 1440p 144Hz G-SYNC.. decisions...
right now 3007wfp-hc 2560x1600
--- Yesterday
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
--- SLI and Overclockability (concerned about the entry level haswell-e limited PCI lanes)
--- Yes, Windows 8.1 Pro 64bit
--- 700-900
--- Yesterday
