Alright, here's a bit of a mystery for me that I definitely need some input on before I make any kind of decision:
about a year ago, the integrated sound card on my motherboard (specs in signature) died randomly. Took my guitar amp head with it, but somehow left the rest of the board intact. I purchased a SoundBlaster xfi Fatal1ty Champion PCI series card to replace it, and haven't had problems since.
Until...
My DVD-ROM died, refused to play DVDs only CD's. So I replaced it with an LG SATA drive. Simple replacement, swapped the cables, used a molex adapter for the power requirement, and turned on the machine. Only to have the sound card no longer recognized by the system. The lights were on on the board, but no amount of driver installation or rollback would get it to recognize the hardware.
So I pulled the card to reseat it and found green gunk all over the leads. It came off easily with alcohol, but placing it into the same PCI slot did not solve the issue. When I pulled the card again, the same green gunk was all over the leads. I cleaned it and placed it in another open PCI slot. This time the card was recognized, but the front panel (with the all important guitar input) no longer functions. Reseating the cable does nothing.
And now, despite several driver reinstalls (multiple versions) the sound card randomly causes serious system errors that crashes my machine. I'm currently working with creative to see if I can RMA,
However, here's my confusion. How could the simple installation of a DVD player wreak this much havoc? Did the sound card cause that green gunk (which I can only assume was corrosion) or was it my mainboard? I'm wondering if I'm working with a black widow mainboard now, and if I should replace it. First my integrated sound card (and guitar amp), then my DVD player, then my secondary hard drive, then my NEW sound card... methinks something just isn't right here.
I have a dedicated power line for this machine, and I've checked both it and the UPS for voltage issues, and I'm fairly certain I can rule that out as a possible cause.
Also, while running PC wizard 2008, it reads my MHz as 1600 instead of 2667, with VERY rare flashes back up to 2667. I know the new Core 2's throttle, but I can't consistantly get it to stay at 2667, even with heavy use in Photoshop, Illustrator, or any game that I throw at it. Problem with the software, or with the mainboard/processor? Every other program says that it's running at the right clock speed.
Sorry for the book, but I'm going out of my mind here. The prospect of having to shell out for a new mainboard and CPU has me about ready to tear my hair out.
TIA.
Until...
TIA.
