Specs of my system
E6600 @ 3.0ghz w/ Scythe Mine - P5B Deluxe - MSI X1900XT - 3x's 320GB + 3x 500GB Seagate SATA II - 4GB Corsair XMS2 DDR2 800 PC6400 - NEC-3550a - Antec TP-II 550w - Cooler Master Centurion - Dell 2407WFP - APC UPS BX1300LCD - SuperPI 1M in 16s
The other day I noticed the computer slowing down dramatically. Thinking it was just something minor I rebooted and moved on.
It started happening more frequently and today it flat out was a suckfest in terms of speed.
I have NO viruses or spyware on this machine. I run Avast and don't ever go to questionable sites.
My main issue is high CPU usage under Hardware Interrupts.
So far I've run chkdsk, seatools, tried several different google searches and have come up empty.
The hardware interrupts will sit around 39-50 and it just flat out sucks my system down.
As far as the event log here is what I have:
Starting just a week or so ago...
Souce: ftdisk
Event : 57
The system failed to flush data to the transaction log. Corruption may occur.
Source: disk
Event: 51
An error was detected on \Device\Harddisk7\D during a paging operation
I also get the same error but says \Harddisk0\
Source: atapi
Event: 26
The driver has detected that device \Device\Ide\IdePort2 has old or out-of-date firmware. Reduced performance may result.
Source: atapi
Event: 9
The device, \Device\Ide\IdePort2, did not respond within the timeout period
Source: disk
Event: 11
The driver detected a controller error on \Device\Harddisk0\D
Same error also ont he IDE Port 2 saying that it
I have nothing on my IDE port 2?
I only have one IDE device the NEC burner. I am currently backing up a good amount of my data onto another drive again for redundancy and am planning on changing out the IDE cable and the SATA cable for the main HDD.
What do you guys think?
I've googled the piss out of this one
Souce: ftdisk
Event : 57
Source: disk
Event: 51
Source: atapi
Event: 26
Source: atapi
Event: 9
Source: disk
Event: 11
