Hardware for 3D rendering
beanman101283
Hi all. I need to either upgrade or build a few machines here at work for 3ds Max work. I'm not familiar with the hardware requirements for this sort of thing so i'm hoping for some general recommendations. After searching around here for a while, it seems that the general consensus is that fast and multi core CPU's are more important than a fast video card. Two of our machines have Geforce 5200's in them. Should i upgrade those? They all have 1GB of RAM.
Any help would be much appreciated.
A bit more info about the specs of the PCs would help.
One is a just-built PC with a 7800GT, single core AMD 3500, 1GB of RAM, and an 80GB hard drive. Another, a Dell, has a 3 GHz Prescott, 2.5GB of RAM, a 5200 video card, and an 80GB hard drive. Another custom built is a 3.2 GHz Prescott, 1 GB of RAM, a 5200 card, and 2 36GB Raptor drives. The Dell is running Vista while the other two are running XP Pro.
Well a good video card does let you see the render a bit more accurately. With that said, I think the 5200 is enough. If not, get the 7600GS AGP since you have an AGP board.
But the most important thing is raw processing power and a lot of RAM. For that 7800GT Machine, see if you can upgrade the CPU to a dual core CPU like the X2 3800. It's socket 939 right? If so, try to buy that CPU used from this forum.
For the Prescotts, are those socket 478? If so, that severely limits your upgrade path. If it's Socket 775, you may be able to upgrade them to a Pentium D CPU.
For all three machines, upgrade all of them to 3GB of RAM. Any more RAM and you're gonna a 64bit OS.
what kind of scenes are you rendering, and are there a lot of polygons in the objects?
working with simple objects in the layout is fine for a slow card like the 5200 but if you have a bunch of high polygon count objects, the layout will run kinda jerky and update slowly when you move objects or the camera views. this is where a fast OpenGL card will help you out, like a NVidia Quadro FX card.
scene rendering is only the CPU, video card does nothing for that.
What I would do in your situation is upgrade the ram and video cards and build a multi cored PC used mainly for rendering the scenes. you can add more rendering boxes as required if your jobs are taking too long to render.
The 7800 machine is an AM2 machine, but either way i don't think it'll be a problem.
Both Prescotts are 478 boards so i won't be able to do much with them. :( I can definitely throw more RAM into them though. I might be able to convince the boss to let me upgrade the motherboard in one so i can use something besides a Prescott.
Thanks for the help so far.
We're going to be modeling the international arrivals areas of various airports around the country. It'll be a bunch of customs booths, lines of people moving through them, and a secondary area where people go for interrogation. Not very high details, definitely low poly count.
So you're suggesting that i have a couple machines for creating the scenes and whatnot and then having one do the actual rendering?
