hardware failure, motherboard died?
black_b[ ]x
I just moved this weekend and now the PC won't boot. Press the power button, fans spin for 1/2 a second then everything shuts down and the power light just blinks slowly. Tried a different video card from an older computer, same thing. Took out everything but the video card and the fans spin up and it seems to be "fine". I'm thinking the AGP port died?
A64 3200+ (754)
2x 512MB Ballistix
MSI K8N Neo Platinum
eVGA 6800 ultra
Danger den water pump
500w PSU
I've had other issues in the last year, sometimes in windows the screen would go blank for 1/2 a second, and a few intermittent crashes so I'm thinking its time to junk this system. The combo of the 6800 ultra (needs 2 molex connectors) and the water pump was probably too much for the PSU.
also... do i fix this thing, or sell the parts and buy a new one? I thought it still had a little life in it but not much.
just confirmed, the PSU was a Fortron 550W, just shy of 3 years ago. ($88 then, woot for newegg order history).
When I booted with the 6800 ultra installed, but without the molex connectors, it beeped really loudly. I think there were a couple times in its life where I got a pop-up in windows about the GPU not getting enough power. Also, it wouldnt boot when i tried to add a 2nd DVD drive.
GPU and CPU were watercooled. only had 1x 36GB raptor and a DVD drive. I could never overclock very far, I think it was because the northbridge had a crappy heatsink w/out a fan, it got pretty warm. Could have been power issues too i guess.
It also wouldnt boot with just the water pump unplugged, so its either the power hungry 6800ultra, the PSU, or AGP slot.
i went over to tigerdirect's storefront in naperville and picked up a cheap 754 motherboard. Tried firing up the old one for a last try and it worked... nothing changed, but I did push on the agp port a little to see if it was loose (didnt seem so). anyway, it works now :)
--edit- and its dead again. the PSU is dead, won't turn on even with disconnecting things and shorting the green/black wires. crap.
