the router is probably my favorite tool,
its certainly the most versitile
once you have invested a little time in learning how to use it
and building a few basic accessories, you can start getting real creative with it
But considering your objective with this mod,
there are alot cheaper methods, consider for example a simple peice of cove moulding with a sandpaper facing that is glued to the inside face of the cove and then attach it to a flat backer to give you a more stability like
.......................handle >| |
backer > nnnnnnnrcnnnnnnnn < plex
......................................................cove ^
clamp the plex (with a pad) to a slick surface and
then you just use that to sand the edge to fit inside the cove
would give you the roundover for alot fewer shekels
you might even be able to use a facier moulding but the corners would be tough
