Hardest Organic Material Ever Designed by Scientists
CommanderFrank
Cat Can't Scratch It
Scientists are claiming that the new discovery could lead to something as fantastic as printable body armor or very light steel. The applications could have wide ranging uses everyday life, but that is likely years away. Did I mention it’s transparent?
It is also incredibly tough. Only a diamond-tipped probe could penetrate the material -- and to make a dent the probe needed to use twice the pressure of what it would take to make a mark in Kevlar.
Directly from the article: "Despite the promise of the new material, it could be decades before scientists are able to translate its design into functional applications."
Mau.... mau..... mauuuuuuuuuuuuuuuuuuuuu
They keep mentioning Kevlar as if it were the strongest, but Spider Silk is stronger than Kevlar.
Last time I checked Spectra beat out Kevlar, so why keep comparing this to Kevlar?. A lot of things are tougher than Kevlar, but it is the ability of Kevlar/Spectra to disperse energy (mostly a factor of the weaving process) that makes it useful for bulletproof vests. This stuff sound useful for trauma plates, but will it disperse energy? I suppose everyone is familiar with Kevlar and Spectra isn't a household name even though it has been used in bulletproof vests since the 90s.
why do they keep harping on about body armor seems like there's many other more practical applications.
The most interesting thing about this is that the body won't reject it since it occurs naturally in the body.
So this is what billions of dollars dumped into Alzheimer's research has found. Well.. at least the military has actually had some kind of advance in the field.
they should have said that it'll be decades before CONSUMERS see anything out of this technology. I'm sure the military will get first dibs on what is made from it.
"Inspired by an unlikely source -- the beta-amyloid proteins found in patients with Alzheimer's disease"
Gangster shoots another gangster. He doesn't die. "You got kevlar or sumthin?"
No bitch, alzheimers.
Probably military funding, which is usually a good thing. A lot of consumer-level products are results of military funded researches. The internet comes to mind.
Why not use it for bullets themselves? I mean imagine a .50 cal bullet that is only penetrable by diamond. You would have to wear it the material just in hopes of being able to stop it.
You want bullets to be dense to carry their momentum.
You also want the bullets to be soft enough to grip the rifling, and to not wear out the barrel.
scientists are always coming up with awesome shit that can be made 100x more awesome..
...with a lot of fucking money..
..that no one gives them..
but at least we get neat articles and a bunch of 'what-ifs'
