i have a thermal take case
http://www.newegg.com/Product/Product.asp?Item=N82E16811133154
and i currently have my hd in the drive bay next to the psu
i check my temps on speedfan, idk if these r the temps or not but i see HD0 and i figure thats my harddrive
i have a seagate 250gb 7000rpm
the idel temp is at 33*C
it doesnt move, is this my temp and if so is it good or should i move it in the other drive bay with the fan blowing in? or should i switch the 80mm mm by the psu hd bay so its blowing onto the hd?
