Hardcore Gamer LF 22"-24"
Bensam123
I've been clinging to my trusty NEC MultiSync FE992 for years. My monitor has started to darken a bit and the top left corner is a bit fuzzy. I've refused to buy a LCD because I play a lot of games, mainly FPS, and ghosting makes me angry. I'm very sensitive to input lag and when it can't keep up with my eyes it frustrates me. If Plasmas came in this size range I would snatch one up right away as they're everything I'm looking for in a monitor (response rates and contrast ratios on par with CRTs). My price range is $300-$400 and currently I'm looking at these two LCDs.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005113
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009152
Anyone in the same boat have recommendations? Should I still wait a few more years before buying for techonology to improve upon itself and stuff like OLED backlighting to become mainstream?
On the other hand I'm just looking for a good new monitor. Does anyone know of any really good CRTs that are still being sold in the 21" range?
Good 22"
LG L227WTG-PF - Only caveat (IMHO) is the glossy screen
LG W2252TQ - Also low input lag, good 22" screen
Samsung T220
Good 24"
BenQ G2400WD/V2400W
Samsung T240
Most of these are low input lag monitors (average under 1 frame of lag), and good panel response.
The L227WTG is listed as having 27 ms average input lag by Digital Versus but no one here has ever complained about input lag, and Prad.De said it basically has none, so I'd be more likely to believe them.
Don't look at the Samsung T220HD/T240HD as they have higher input lag than the "non-HD" versions listed here.
Either one you've listed might be ok too, but these here are a bit better in overall quality of panel, OSD, etc... The Acer is ok, but the LG W2452T is probably a bit better of the two you listed.
