It doesn't matter what orientation a hard-drive is mounted as long as it doesnt change while the drive is running
I've always heard that you want to keep it either flat, on its side, or straight up and down. Odd angles are supposed to be bad.
Since there is no physical contact between the bearings and the walls of the housing, it is irrelevant. That's why there's "Fluid Dynamic Bearings."
If vertical versus horizontal actually affected life expectancy, large scale arrays would not exclusively mount drives vertically. Yes, exclusively - no major high end array mounts horizontally. They're all vertical, because it improves density. (16 per 3U)
I've had drives between 90 & 0 degrees with no problems.
lolO yea....well have you tried them from 90-180 degrees?![]()
