Hard drive temperatres
Flogger23m
Just wondering how hot is too hot for a hard drive?
I have a WD 1TB FALS that is running at 45 degrees C. It will go up a bit more in the hottest days of summer.
Is this average for a hard drive, or a bit much?
45C is ok. Just look at the max temp rating for your HDD and try it to keep it under that.
Ok, thanks for the info.
I am assuming I can find this info on the HDD itself?
45 is fine I would put a fan in front of it though. Even a small 80mm running at 25% speed can cool it down a good 10c
