Hard Drive Replacement
Discussion in 'SSDs & Data Storage' started by MajorM, Oct 2, 2015.
  1. MajorM
    MajorM n00b
    40
    Aug 12, 2010
    I have a 1 TB hard drive that is going out and I need to replace it before I have any major issues. I have allot of data on it as well as my OS so im thinking about increasing the capacity to around or over 2TB. Im using about 3/4 of my current capacity. So what are some good options for capacity and speed with the current offerings? I havent had to buy in a while other than a few SSD's so im not sure what is good now with the spinning drives.
    I know it would be nice to have the OS on a SSD but right now I dont want to buy two drives and the high capacity SSD's are more than I want to spend.
    Thanks for any help.
  2. Deadjasper
    Deadjasper [H]ard|Gawd
    1,714
    Oct 28, 2001
    There's always refurbs if money is of prime importance. I just bought 2 3TB Hitachi 7200rpm drive from eBay for $65 each. At this price I'm willing to take a chance. I've had good luck with refurbs and on the rare occasion I get a bad one, the seller always made it right.
  3. cyclone3d
    cyclone3d [H]ardForum Junkie
    13,105
    Aug 16, 2004
  4. Aesma
    Aesma [H]ard|Gawd
    1,844
    Mar 24, 2010
    Do you have backups ?
  5. mnewxcv
    mnewxcv [H]ardness Supreme
    6,483
    Mar 4, 2007
    I've had good luck with hitachi or HGST.
  6. zaniix
    zaniix Gawd
    895
    Nov 4, 2011
    I have had great luck with WD Blacks and Reds, the reds actually work really well as a secondary drive. I still use a Black 4tb as my data drive, but I am no longer sure it really provides that much advantage over the Red for what I use it for.
    My 500gb SSD is more than enough for OS plus games and apps
  7. diggi
    diggi [H]Lite
    109
    Oct 3, 2012
