Hard Drive Recommendations? - Long Life
Accursed
Hello, Building a simple mail server for about 60 users. Using a Dell PowerEdge R210 with no on board RAID. Any Recommendations for a Hard drive that's reliable and has a long life. Speed and such aren't important.
Any recommendations? 250GB or greater SATA drive...
Thank you in Advance.
Look for SAS drives if you want longer life than the 5 year expectancy of SATA drives. Although even SAS drives will die.
Hmm, So maybe I should just bite the bullet and get an add on RAID card?
Thank you for the tip.
Any recommendations for a simple SAS Raid 1 card then? I'm guessing not much difference from one card or another...
Edit: No looks like their is a bunch of differences in SAS cards...
If you want to keep it cheap go WD Black.
5 Year Warranty.
You can send them in at 4yr 3/4 for all fresh drives if you need.
2TB should last you a while I`d imagine... then you can step up to raid down the road, etc.. I'd run RAID/Mirroring from the start if it were me.
5 Year Warranty.
I have had a really good track record with WD too.
5 Year Warranty.
Those die however just like any other SATA drive. At work where I have 200+ drives, I have 1 WDC black drive and 2 Seagates going out for RMA this week which puts the total to 8 drives RMA'd this year all of which were less than 3 years old. Lets see 4 seagates, 2 WDC blacks ,1 samsung and 1 hitachi. Hmm. I think we will break last years 7% failure rate..
I have an older 500GB Seagate running 24/7 for 4yrs. Awesome disk if you ask me. Not sure if SAS drives are worth it, though, but I wouldn't buy them.
How much more reliable are your SAS drives?
I just decommissioned a web server from 2003 that had been running 10+ websites 24/7 and doing 10-15gigs of backups per-night in a controlled data-center with 2 WD SATA Drives, and RAID1.
1 drive was replaced in 2004, and since then no replacements.
Running 24/7
