I am looking for an eSATA Hard Drive dock with built-in memory card reader and usb hub. Can anyone recommend a good one they have seen/used? Having trouble finding the ones with built in readers for some reason.
I found these 2:
http://www.amazon.com/exec/obidos/t..._shr?_encoding=UTF8&m=A1CUXCEWGAZ8O2&v=glance
(says 1.5gbps, but if it's eSATA, then it must be capable of 3gbps, right?)
and
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4146240&CatId=2785
Any others I might be missing out on?
I found these 2:
and
