Hard Drive Bay Wires
ColdCrow
I would like to put a few more hard drives I have laying around as some secondary storage. Only problem I have is I can't get the power cables to come through correctly to these drive bays. If I do manage to connect a few hard drives the cable prevents the case from closing. Anyone suggest any easy power cords that are easy to work with in tight spaces?
I should be able to fit at least 4 more hard drives in this case, only thing stopping me is the cables.
Which cables? Did you mean all of them? i.e the power cables and the sata cables?
well the power cables are the real problem because they are just hard to bend to get all 6 hard drives plugged in. Sata cables are not the problem, but if there is an easier way I would prefer it.
Now you just gotta buy more if you need it.
SATA cable wise, get some right or left angle SATA cables.
