Where do you get one of these?
Basically it seems theres problems with my motherboard, ASUS A8N-SLI Premium, and it's nForce4 chipset. Every hard drive I use makes this grinding noise, right out of the box, ATA and SATA. I know most say that's a sign of death, but I've read cases blaming the problem on drivers and windows xp. The drives weren't really dead. My motherboards also know to have issues recognizing hard drives. I'm not running RAID, although the SIL SATA RAID screen comes up during bootup. When I'm suppose to be running nForce4, not SIL. SiSoftware Sandra is saying I'm using an ATA, when I'm only using a SATA, and says my "block size" is only 10 and needs to be increased in the BIOS, which I can't.
I'm thinking I'll need to get the motherboard RMA'd, but at the same time I think I'll still have the same problem, it's something wrong with the boards.
So what's a Controller, physical chip or software? Can I use any other chipsets than nForce4? Is there any beta ones? How do I increase my block size?
Could it have been my old BIOS I updated that caused the problem? Think the noise will go away if I Low Level Format it?
