bman212121
- Aug 18, 2011
all MS needed to do to make vista a success was to make device manufacturers release stable drivers for the RTM, and mandate a 2GB minimum spec for a vista premium sticker instead of that 512mb crap they tried to pull, and people would have loved it...
after windows 2000, I still think vista had the best UI look/skin of any windows release
I absolutely loved Vista and still find it very usable other than the super annoying disk thrashing on clean install. That is so easy to notice, especially after having dealt with 7 so long. I couldnt wait to get XP of my system. The only reason I retired Vista immediately is because I got 7 free. I still really like the darker UI of Vista, but the 7 additions of task list and snap keys were a big enough productivity improvement for me to prefer 7 over Vista by a long shot. I'd still take Vista over XP any day.
Not to minimize that some people had problems. My systems could easily handle it, but MS did set the reqs way to low in order to appease intel and the OEMS. Vista never should have shipped on anything with less than 2GB. The hardware vendors also were a big part of the problem. It wasn't really MS's fault they didn't get their shit together, they had plenty of time. I was running Vista betas for at least a year prior to launch and nvidia never once released a driver update in that time, iirc it was like a month after GA before they did.
The memory and disk thrashing were the biggest problems for Vista. Because the OS was a complete redesign it had a much steeper requirement than the previous operating system. A sub par pc that was running XP definitely wasn't going to run Vista.
There are still pcs out there running Vista on 1GB of memory, and I can't help but wonder how people are using those. (Just had someone ask me to fix something on a laptop with this config) After the operating system, an AV solution, and a few other things boot up the system is already out of free memory.
The disk thrashing I think was the biggest issue for clean installs. Anyone who is tech savvy knew to turn off superfetch, readyboost, system restore, and windows search. Those features weren't quite ready for prime time and just added to the extra workload. After disabling those I never had issues with disk thrashing. If we had SSDs when Vista came out this would have likely been a non issue.
